how hard is it?
my89sho
NC
if anyone can tell me how and what i need to do to change out my alternator for my 89 mtx. i've changed out alternators before in different cars. they were always right there in front. please help.
[This message has been edited by my89sho (edited 11-11-2001).]
89 Gary
Millbury, Ma.
Remove battery,battery tray,loosen belt tensioner front and top bolts,loosen pivot bolt,remove belt,remove all electrical leads/plugs,remove three bolts holding alternator,now clean tray/sand/then paint if needed,apply never seize to all bolts after cleaning with wd-40/wire brush,bolt in new alternator,put on new belt if needed,re-tension to specs (I tighten enough so I have 1/2 inch deflection when I push down on belt). Complete and check after running to make sure belt is not to loose or too tight.
9
94ShoATX
Guest
Its real easy!
