How do you remove Black dash panel???
sleepa
Wisconsin
I want to paint my Black dash panel that goes around my gauges, clock, digital climate control, and light switch! where are teh screws for this thing???is it possible to remove?? please help ASAP, id like to put a coat on it yet tongiht!! thanks!!
Hubes
Burl., MA/Chesapeake, VA
is the part that has the vents in it also. well 2 vents out of the 4?. if so i could probably tell you how to do it, i just need to know if that is correct.
blewbyu
The Lone Star State
once you remove the headlight switch cover, it pops out of place with some patience. boink If you break it, let me know, i got a couple of extras. wink Craig
sleepa
Wisconsin
OK, so there are no screws or brackets or nething holding it on?? it just comes off huh?? alright..ill give er' a try..thanks man
SHOMA
Springfield, MA
There are 2 screws above the instr. cluster, and 1 on each side of the column.. You have to remove the metal piece that would be in front of your knees, to gain access to the screws.. A total of 4 torx between the top and the bottom by the column, and THEN it comes out with patience..
Good luck!
Kevin
