How do you pull out the headlight switch?
LarrySHO10
Moses lake, WA
So apparently the SHO has a gremlin. I think my headlight switch is out in my 2010. It happened to my son once last winter and now it happened to me. So I'm thinking its the remote start somehow. So after I replace the switch, no more remote starting I guess. Anyway, I was wondering if anyone can tell me how to pull the old switch out?? I'd rather not destroy any necessary plastic around it trying the wrong way to pull it. Thanks for any ideas.
6500rpm
Removal and Installation
Remove the instrument panel side finish panel.
NOTE: The 3 retaining tabs on the headlamp switch bezel are located at approximately the 5, 8 and 12 o'clock positions when viewed from the front.
Reaching from behind, release the 3 tabs and push the headlamp switch and bezel through the opening.
Disconnect the electrical connector.
NOTE: The 3 retaining tabs on the headlamp switch are located at approximately the 3, 7 and 11 o'clock positions when viewed from the front.
Release the 3 tabs and separate the headlamp switch from the bezel.
To install, reverse the removal procedure.
LarrySHO10
Moses lake, WA
Oh my gosh that was easy. I think it took 5 minutes from the time I walked out of the house to the time I walked back in. Thank you so much for that assistance 6500rpm! Sure do appreciate it!! :)
