HOT PIPES?
mybigsho
new york
Looking to order hot pipes for my sho.. How should i order for stock replacement? Bov, mounts,??
Too many choices on the order form..
Thanks..
bpd1151
Lurking Around
SHOcago 'Burbs
If you order w/o the factory (electronic) BOV's, then you'll have to keep them plugged in, but zip tie them out of the way/out of view.
If you're planning on going with an aftermarket BOV, then order the pipes w/o the factory BOV mounts.
Otherwise, save the hassle and just order WITH the factory mounts.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
like above, really just depends on if you want to keep the factory BOVs or move to an aftermarket unit. you'll need one or the other.
FiveLeeter918
Tulsa, OK
Aftermarket is better quality over the oem plastic. I personally havent had any issues with the stock BOVs but starting to find a lot leaking with elevated boost.
Wsho
Sacramento California
New hot pipe don't have plastic I wasn't asking about the hot pipes I was asking about the BOV oem -V- putting in aftermarket BOV is there a difference?
FiveLeeter918
Tulsa, OK
Yes I'm referring to the plastic BOVs.
Wsho
Okay so you're saying the plastic parts on the BOV can leak so what can you replace the OEMs with? will the aftermarket ones bolt on to the OEM mounts? Anybody have a suggestion of what kind to get to replace the OEM ones
FiveLeeter918
Tulsa, OK
Nothing is made to replace the oe BOV, best bet is to upgrade to the TiAL or other single bov as used in Mike's hot pipes.
Jordan_R
Missouri
Just my two cents. Running 20psi on stock BOV's with no issues and have been running high boost on them for the longest time. The aftermarket BOV isn't worth the money imo unless you want a hot boi BOV noise.
Wsho
Yeah I think I’ll leave it stock for now until I forgot out what all that stuff means.. LOL
76FoMoCo
Nampa, ID
Mike must have a supply issue as I ordered mine last week and just seen the ups tracking label got printed...
FiveLeeter918
Tulsa, OK
The coronavirus killed his coupling supply, they just finally came in. Everything was welded up and coated last week, he's still waiting on the new "S" coupling to come in for the rear turbo, told me last night he's 5 days out on them.
76FoMoCo
Nampa, ID
Good news tracking shows it shipped! Need to get my boost leak fixed so i can finish my AJP e30 gh ic and xdi 35 tune done and send a log to gh on the e30 to to see if I can get a final nodd or a revision before my 30 days pass
FiveLeeter918
Tulsa, OK
30 days?
