Highflow Magna Flow y-pipe donut????
MADDOG11
Houston, Tx. Denver, home
I got a Magna flow y-pipe from SHO Source and the ****** gasket will not fit onto the ****** without cracking (too tight)!?! Any ideas on a different part # for the gasket or any other help??? Thanks, Kevin.
AREA 91
PA SHO SHOP
Area 91
1995 FORD TAURUS SHO 3.0L 182cid V6 MFI (Y) : Exhaust : Exhaust Pipe ****** Gasket
Item Price Core Total
FEL-PRO Part # 60641
Dual Overhead Camshaft Engine; Converter
$5.17 $0.00 $5.17
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
I have found solved the problem a couple different ways.
First, there are donuts that will fit. Typically they are the more expensive ones at the part store (they usually offer 2-3 brands at NAPA or Shucks/Checker/Kragen). The better quality seem to fit better on the Magnaflow pipes. I have had good luck with the Felpro gasket, but lately they have even been substituting the low quality ones and rebranding them as Felpro.
When I can't get my hands on the right donut, I have made a low cost one work by using a dremel/die grinder/rat tail file, to gradually open up the inside. It is a pain, but it will work.
FYI, this is one of my personal parts problem pet peaves, so we at SHO Source are looking at identifying and stocking the correct fitting donuts so you can buy them in the future and know you will get the right part.
Mike
Nicad
hoostin
Used a 1.5" drum sander and enlarged the ID of the "stock" donut as well.. Works great no leaks.
Satchmoz
