shorook90
guys I need your help again! My damn secondaries are still not opening after finding a vaccum leak. Well what could it be an actuator or another vaccum leak? If another vaccum leak, how can ford locate the leak? thanks a million
They must be stuck closed, because the deenergized position of the secondaries is the open position. Did you disassemble the intake recently? I think you could get them jammed if you didn't put everything back together correctly. Remmber, engine off and above 4k rpm secondaries open, 0-3900 rpm they should be closed.shorook90:
I guess I misunderstood you. If you can move them by hand, then I would keep looking for a vacuum leak. There should be a vacuum supply, make sure you have vacuum suppy there. Also, make sure both of the runner butterfly actuators have their vacuum tubes connected. Probably the best way to make sure you are connected right is to compare your car to another SHO. After you make sure the vacuum is routed right, then check the electrical circuit.shorook90:
sorry i meant closing. my secondaries are closing at start.* sorry thanks
