help me for this problem urgent
thibertsho
montreal
hello i have a problem with my sho 5 speeds 95 it lacks force one would say that it run too rich or not enough is you it possible that it would be oxygen sensor or timing?
thibertsho
montreal
ok i changed the 2 oxygen sensor and y pipe very new catalisor... not change lost power again?? what is the trouble.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Why do say there is a loss of power? What are the symptoms?
Have you done anything to the care lately?
thibertsho
montreal
to idle is run very good but in first gear acceleration is not good it take the gaz slowly
SuperHO
Mental Patient
St. Joe, MI
When's the last time you cleaned the MAF sensor or changed the fuel filter?
Redskull
Badass Mo'fo
New Haven, CT
definitly start with the MAF sensor and Air Temp sender. It's cheap, quick, isn't going to hurt, and can make your car run like new
thibertsho
montreal
ok tomorrow I clean the maf and to change the air temp sensor thank you i give you news
LOUDSHO92
Sponsoring Vendor
Is your throttle cable stretched? Have some one floor it and see where the throttle is at WOT.
thibertsho
montreal
thanks you for all council guys to it (maf) I cleaned now is a normal sho i am very happy ALAIN
