HELP!!! Hooking up starter!!! 3 wires?
SHO SPD
SHO member #480
Naples, Florida
Ok, I cant remember how I unhooked the starter, so there is the problem hooking it back up, I got the black ground wire hooked onto the bolt with the nut twards the tranny... but heres where I am stumped, there is 1 red wire that goes on a bolt, and another red ended wire, with a braded bre wire comming off of that one, well Where do I put those wires? there are two bolts with nuts, does one go on each one? bot on the same one? help, I am screwed... I did try them both on the top bolt, screwed the nut on, but te car just gave 1 click, so thats not right.. HELP!!! g out to yur car and check, or please help... (this is not the same starter as an 89)
93nighthawk
Mitchell, SD
The big red wire is the lead from the battery, then you have two wires that come together to a connection (that is a lead from your alternator & going God knows where), You put both of them on the same bolt, It is the closest one too you (from looking up under the car, the solinoid is biggybacking the starter right?). First slide the two wire on, then the battery line on, tighten good. It should work, but it sounds like you do not have enough juice in the battery to turn it over.
Eric
hess_sho
