HELP!! Crank bolt won't budge
qiksho
SHO Addict
Fargo, North Dakota
I am in the middle of the 60k process. I have the upper timing belt cover off, accessory belts, idler pulleys, intake, valve covers, battery all off.
I am going by the instructions in the Ford shop manual and my next step is taking off the bolt on the crank so I can remove lower and mid timing belt covers and water pump.
Problem is I have tried air ratchet with 110psi of pressure, manually with 1/2 drive ratchet while car is in gear and brakes are on. Neither approach budged the bolt.
From the looks of it I don't want to use heat on it since there is a rubber seal.
Can I use the starter and a breaker bar to loosen the bolt?? (Keep in mind I have intake, valve covers, and all accessory belts off).
If not how do I get this damn thing loose? :mad: cuss
If you do that put the valve covers on gently to prevent any oil from shooting everywhere.
<small>[ June 28, 2003, 03:48 PM: Message edited by: luigisho ]</small>
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Using the starter method will not do any harm.
I used it a few days ago with EVERYTHING apart eek! :D
Oilpan, timing covers, CPS, timing belt, etc... etc...
Just use the starter method. It works thumb
I wish I had done it before trying to remove that damn bolt using other methods headbang cuss
