Heater line epiphany
Devin
3.Slow
Pacific Northwest
After possibly toasting my engine I finally got around to fixing the metal/rubber heater lines. At least one of them was leaking under high pressure but I was putting it off because the metal crimps on the rubber lines on the engine side looked complex to fix.
Well, after going to an industrial supply company (my thanks to Greenshields!) to get them fixed, it turns out the metal crimp is nothing more than a permanent hose clamp. The guy at the shop slit the crimp and pried it off, replaced it with some heavy duty silicon hose and I can just replace it with a screw-type hose clamp.
Why would Ford put a metal crimp on one end of the hose and not the other, and why not just use their stock spring-type hose clamps? This makes me wonder if someone altered my supply and return lines.
AREA 91
PA SHO SHOP
Area 91
They all came from the factory with those "crimp" connections.
My guess is that they were pre-fabbed, and installed as they went down the assembly line.
I have replaced multiple SHO heater core lines with bulk hose and worm clamps. It works just fine.
itwonder
VA
Remember, search is your friend. The fix procedure has been written up quite a few times in the past.
