1) yes ARP does sell studs/bolts for the SHO,just not in sets....u buy the bolts individually(u will have to supply length and thread pitch). Just like. Cosmetic sells SHO gaskets,ARP sells SHO bolts.....
2) no sir. Studs clamp from both x and y axis where as a bolt only clamps on 1 axis,the threads. Studs are way superior in clamping force.
3)wrong again. The studs come with an Allen head on the end so you can remove from the block. A 4th Gen F Body doesn't have anywhere near the umderhood room a SHO has and head studs are EASILY removed. Same on a Buick GN with the heater box over the PS cylinder head. You just remove the stud before the head.
