harmonic dampiner bolt stuck
1ekoms
Houston
Im have a smokin 95 SHO AKA leaky front main, so im going ahead and replacing the water pump, crank sensor, timing belt, cam seals, and front main, but i cant get the damn bolt off the harmonic dampiner.
tried penetrating oil, impact wrench, strap wrench & socket wrench
any suggestions, tips or tricks would be appreciated
autobahnsho
SHO Victim
NY for now, WY for real
Give the "starter bump" (a famous SHO legend here) a try.
You put a 'disposable if it breaks' wrench on the bolt. You brace it against something, and turn the key to make the starter turn just a little bit. This usually loosens it enough to get it off. Be careful and you'll be fine.
masho95
got Zex?
Chicopee, MA
If you try the starter bump method, never had it fail on multiple cars, make sure you use a 6 point socket! 12 point sockets tend to round the bolt, although I've had them work before, but I definitely DON'T recommend it. If you are still lost on the "starter bump" method do a search for it and I'm sure you'll find exactly what you'll need. Good luck.
