hard wiring speakers
Chris Jennings
nacogdoches, tx
well, guys and gals, i tried forever to find my short in my radio wiring....to no avail....
so I removed the whole wire (containing the speaker inputs) that ran from the radio to the amp to find nothing out of the ordinary. madflame
Now I am going to hard wire the speakers, but I have a decision to make... Should I run all the wires to the rear and tie back into the "post-amp" connection....even though I will have no amp anymore...dice and splice or run straight to the speakers? shrug .....and i do have a good headunit with builtin amp....
i do understand that posibly the short is in the 'postamp' line so thatd be a chance, albeit it easier.... headbang
Are you using an ohm meter to look for the shorts? It will tell you if the wiring is grounded or shorted together.
Chris Jennings
nacogdoches, tx
i did do a continuity test from the radio out to 2 of the speakers (the two that were shorting) and that turned out fine, but no ohm test.....
BlankDisk
New Mexico
I will tell you from experience, ALWAYS hook up your speakers to an Amp. One day I decided to hook up two 10" woofers to my system, and hardwired them to the system. Now they sound like normal speakers, and can I barely notice a diference. Just run new wires and use an amp.
