Guages I Need Help
lunchbox0029
Fort Worth
Gauges I Need Help
I need help I'm putting some gauges in my 95. I'm putting air-fuel, oil pressure, and voltmeter. The voltmeter I knowto hook that up. But the air -fuel and the oil pressure I'm not sure. The air-fuel to the O2 sensor not sure what wire do I hook it up to? The oil gauge I have no clue.
The oil pressure you will have to tee in another sender to the existing one fro the oil pressure light.
Don't know about the A/F. Always heard they are just eye candy unless you get the wide band.
There is the EPC port on top of the tranny that you can screw a sender into for the tranny temp. 1/8" pipe thread.
You need a tee to mount it and the original one in the same location.
Markus
Ottawa, Ontario, Canada
Correct. The other problem is that there are 2 sensors on the Gen 2. A single gauge cannot monitor both. If someone really wants/needs to monitor A/F I would think that monitoring only one O2 sensor would be meaningless. For those of you have A/F gauges, which O2 sensor did you tap.
To the right of the oil filter with one wire connected to it. Try to use a brass 1/8"MPT x 1.5" ****** for the block. You can use steel but brass is better for the aluminum.
