1993MTXSHO
Its a Taurus...
I can't seem to find anything about which filters are good or bad in a search so time to ask. I found a fram filter on summit racing, but is the fram filter a nono? What would be a good filter to use if fram is bad, I plan just dropping the pan and replacing the 6 qts of fluid or w/e comes out and putting in a new filter. I need this tranny to last as long as possible so is there anything else I can do becides half new fluid, a new filter, add a second trans cooler, and don't beat the **** out the trans? BTW how hard is this o change (the filter); if there is one thing I don't know a lot about its transmissions.:thankyou:
not that hard. Make sure the clip holds the filter tight. bout it.
