SilverSHO
I finally did both KOEO and KOER tests today.
KOEO:
KOER:
I also did the Cylinder Balance test, and it told me cylinders 1 and 3 are weak, which I'm thinking has something to do with the 41 code.
My questions: can anyone help translate these codes?
Also, where is the SPOUT connector? I found one unused female connector near the back (driver's) side of the rear head; the connector itself is oval-shaped, and has a rectangular clip around it. It sits right on a wiring harness, with almost no slack in its wiring; it runs right into the harness. I'm thinking it has something to do with the EGR system because right next to it are threaded holes consistent with the location of the EGR valve/tube on CA cars.
Nick
Lt. Titanium 90 135k
Coneless, ACCEL 8.8 stainless steel wires,
SHO Shop torque limiters, Cherry Bomb Turbo II mufflers
AIM: loudog6491
[This message has been edited by SilverSHO (edited 11-16-2001).]
KOEO:
- 14 (PIP circuit failure. Suspect PIP sensor or TFI module, or grounding or interference problems at the TFI module)
- 49 (SPOUT signal defaulted to 10 degrees BTDC; SPOUT ciruit open)
KOER:
- 21 (ECT out of self-test range)
- 41 (HEGO sensor circuit indicates system lean (rear))
- 73 and 25 (25 means knock sensor not detected and 73 means i didn't goose it hard enough, which kicked out the 25)
Nick
AIM: loudog6491
