Gen3 '99 Taurus Windshield Wiper hose replacement
Qshiplvr
P Springs
Has anyone ever replaced a cracked hose that supplies windshield washer fluid to the squirters mounted in the hood? I noticed this the other day and thought to myself: "THAT doesn't look right..."
I ordered a replacement from Rock Auto that was supposed to replace OEM part number 3F1Z-17A605-AA
Until the part arrives, was wondering if just duct taping the hose together would work in the interim?
Bob from Accounting
Texas
If it's brittle but solid, cut it free and dress the ends, slip a large plastic straw over it, shrink it tight with a heat gun making sure the ends will flow (almost but not quite touching) and cover with silicone or a silicone tape. Taping it will just crush it as you wrap it. That's if you can't just replace it with tygon or something durable; if it split there it is likely to split again especially where it connects if you work it enough.
Qshiplvr
P Springs
Bob from Accounting: You have a better grasp of the situation...the hose is very brittle...so brittle in fact that I think if I try to go w/ luigisho's suggestion of trying to connect both ends with a male/male connector, I will simply cause the hose to crumble. What was once flexible and pliable is now quite brittle and INflexible. I'll see if I can find a plastic straw of the appropriate diameter to fit over the hoses. Not sure if I have any heat shrink / heatgun around. May go w/ silicone tape. Thanks again for the suggestion!!!
Irish Pride
Irish Inside
MusicCityUSA
Cut out the bad section and use rubber vacuum hose to reconnect the two ends. Slide the hard line into the vacuum hose. Use extra length so the line can bend and flex. That will take care of the current bad section. For a more permanent fix cut the hard line closer to the jets and use vacuum line to replace the bulk of the hard line.
-Chad
raymo23
