gen II rear brake question
cetroutt
troll
SEMO
well my SHO sat for to long and now the driver rear brakes has locked up tight. now i have gen III SLO for parts and what not. i'm wanting to know if i can use the calipers off of it on my SHO? it seems i once read somewhere that the gen II had the same calipers in the rear as the gen III SLO's. and if i can use them should i pull line and caliper or just caliper? i know the SLO has less miles and is several years newer plus it was driven by an older non aggressive driver. thanks
chris
sho'noffmtx
Many SHO's
Delano,MN
It could be just a rust slider pin that holds the caliper. I would check that first before going through the trouble of switching calipers.
Satchmoz
