Gen 1 Steering Rack Removal and Installation
91-SHOPLUS
I'm about to replace the steering rack on my 1991 sho. I know i've seen a step by step guide to removing and replacing the rack but I can't find it. Does anyone have a step by step guide?
I would say, disconnect PS hoses for the cooler and the pump. Pop the outer tie rod ends out. Then drop the back of the subframe as much as you can, may have to loosen the steering column pinch bolt. Then loosen the two large bolts holding the rack in.
