Gen 1 & 2 owners, still running the original Yamaha engine?
Shaggy
Administrator
These old SHOs are getting up there. Is yours still on the original V6 or has it been swapped or rebuilt? How many miles are on it?
zoomlater
Seattle, WA
94 MTX 69K, upper 60K
92 MTX 96K, front 60K, replaced header panel and lights
94 ATX 157K, front 60K, now a parts car
Irish Pride
Irish Inside
MusicCityUSA
Not even close
Se7en - 1995 Moonlight Blue MTX - Stroker crank, bored to 93mm, high compression 10.25:1 Wiseco Pistons, 3.4 Liter displacement
Opal - 1991 Oxford White non Plus - Stroker crank, bored to 95mm and sleeved, high compression 10.5:1 Wiseco pistons, 3.6 Liter displacement
Yuki - 1991 Oxford white Plus Package - 3.2 swapped, low compression 8.5:1 JE pistons, Vortech Supercharged with 18 pounds of boost at 7K rpms
-Chad
TankII
Bolton, CT
'91 - Swapped motor and Trans (added Quaife) at 184K miles from a '90 - that 3.0 had more torque. Replaced the main bearings at that time. Replaced all the bearings in 2017.
Replaced the injectors, but it was the computer that was the problem (2018)
Last year did a '96 subframe swap and new Clutchmasters clutch
Currently at 262K miles.
raymo23
