fusible link issue on 1990 sho
Fordtaurussho
Manitoba
i have four bare wires that are supposed to go to fusible links then to the starter solenoid, yellow wire with white tracer, ********* wire wire with yellow tracer, yellow wire with gray tracer and big beige wire with red tracer, what gauge of fusible link goes on each wire and where do they go from there?
projectSHO89
SHOless In St L
Without looking them up.. Fusible links should be two wire gauges smaller than the wires being protected.
ie, if the circuit is a 14 ga wire, use an 18 ga FL, If a 10 ga, use a 14 ga FL, and so forth.
Fordtaurussho
Manitoba
those are four bare wires, where do the go too? on my 1990 sho, there are supposed to go to fusible links, now are some grounds or are some power? near the starter solenoid
Satchmoz
