Now I'm thinking I might keep them after all. Yesterday I took off to town and the first thing I noticed was that the tires were not doing the same things on the broken sections as the day before. So I drove around enogh to be sure it was not just me, and then went in to talk to my favorite tire guy. He looked at the tires a while and asked what pressures I was running these days. I told him same as always, 36 front, 32 rear. He said something like, well, pretty cool today compared to the last week, and smiled.
Damn. The compound in these lower cost tires is apparently much more subject to temp changes. So, as a solution to overcome the softer rubber he told me to try running the pressures up a good deal to keep the overall tire stiffer. He said that a lot of these lower cost performance tires really need to be run at near the max tire pressures in the front at least, just to keep them from squirming. So, I am trying 40f/36r and latter today it is supposed to get pretty warm and sunny again, so we will see if that works. They are rated for up to 44psi, so I can crank them up more if needed.
But just in case, I still have 4 new Bridgestone Potenzas on order and I will just toss them into the garage as backup.
Have any of you had this sort of thing happen with lower cost high performance tires?
pax, smn
