Front turn signal?
Glue Maker
The V8 Paradox
Sugar Land, TX
As soon as I get some spending money, I wanted to change out my front blinkers to those cool new SilverStars. But how would I go about doing this? shrug
99V8SHO
GasOilAndTires
Gaithersburg, Maryland
I actually took the top few botlts out that holds the front clip to the car, enough that I could bend the clip forward just enough to get the bulbs out and replaced. PITA. I could not find an easier way.
wild01ride
Back in time...
Plymouth, MI
The easiest way to do it is to take out the headlight assembly.
Remove the three, small 10mm bolts and loosen the long 10mm bolt/post (all four are silver-colored bolts). If you remove the bolts and then loosen the long post, the assembly will begin to slide out on its own.
Pull the entire assembly forward out of the car and disconnect the headlight connector.
You can easily access the signal bulb from the headlight opening without having to crank on anything or bend anything.
Glue Maker
The V8 Paradox
Sugar Land, TX
Thanks for the replacement advice. Finally got and installed them :D
Kind of rice... But better than orange thumb
99V8SHO
GasOilAndTires
So what did you run with the stock turn signals and with the Silverstars? Did they shave off some time? thumb
No but seriously, what did you run?
Glue Maker
The V8 Paradox
Sugar Land, TX
finger I think they were only worth 2 extra hp headbang
It was a slow night. I dialed in a 10.2 (its an 1/8th) but I broke out bad 2nd round with a 10.13 ******* the brakes rant Could have been another 9.9 night. This was all on engine, AND K&N!!!! :p I wouldn't say the drag radials didn't help... :D I can't wait until winter, Texas sucks!
<small>[ November 03, 2003, 04:46 PM: Message edited by: Glue Maker ]</small>
