FogLights & Front Speaks
Fletch
Orlando
I have checked the fuse ontop of the fuse release bar and located another which i think was 4 my alarm and both were good, So i'm thinking it is a wiring problem? A little help please headbang
As for the front speakers i have no clue...they just don't work and it's not the fader, ideas and suggestions would b greatly appreciated.
Thanks. Fletch
buechine
Ontario, Canada
As far as your fog lights do you actually have power down by the light sockets? On my older sho I had the sockets rot out which may be the issue, check the wire under the car by the fog lights to check for power. As far as the radio is concerned blown speakers? bad head unit? Try swapping another deck if you have one readily available.
Camarok
Awesome SHO Member!!
Milwaukee, Wisconsin
Do you get any fuzz or sounds from the front speakers? Maybe the amps are screwy, or connectins at the amp, or behind the head unit. or for 25 bucks, you can probably get your head unit looked at.
