lmuscella
I have a 98 SHO which always seems to float at speeds higher then 80. I put new tires on and had a alignment done but no change. I'm afraid to go much faster for fear that the car will get away from me. Any ideas?
This might sound stupid but what is a sarc switch? I am not familar with this.Originally posted by CMurderSHO:
The floating feeling you feel is normal. It is because when the sarc system is in soft mode it is so that you do not feel the bumps in the road. That because they wanted it to be a very smooth feeling ride. When you are at higher speeds it is supposed to make the struts and powersteering stiffer so that you have more feel for the road which is what you want at high speeds. You have much more control with it in stiff mode. The factory computer does not seem to put the system into full firm quick enough and that why making your own sarc switch is nice. You can turn off the sarc sytem and the struts go to full stiff and you get limited powersteering which combined with some roush lowering springs really tightens up the ride. You will not float with the sarc off.
Are you saying that the 98 were prone to float but the problem was fixed in 99. I would hate to throw a switch everytime I go over 80 mph.Originally posted by LASTSHO:
My speedo's ok all the way up....early 99's had that problem I believe. But definitely the 98's.
Originally posted by stephen newberg:
No, he is saying on the '98s and early '99s the speedo stops registaring and drops back to zero when you hit about 110-115 mph. The car keeps right on going up to the 140+ max, but the speedo is out of it. This is apparently a flaw in the computer that sends data to the speedo and no one has come up with a fix.
"Floating" is not a major problem for most people, so long as you are not running on very smooth roads most of the time. The computer stores data on how you drive. Mine tends to stay at hard almost all the time just on past data, and if it gets too soft, you can just flip the switch for the SARC.
pax, smn
