SHONUT91
Worked on this problem for a couple of days,ended up being the same problem as Nebraska SHO had.
There are two small wiring harnesses coming out of the steering wheel assembly on the right hand side,just under the ignition cylinder.Traced these wires too, two connectors that are attached to one of the dash support brackets(they are two grey plug in connectors.)One of them only has two wires leading into it,the other one has four(this was my problem connector.)
Three of the wires had been pulled or broken loose from the connector.Went to the local salvage yard and retrieved one from a parts car(they are not the same as far as I can tell between regular taurus and the SHO,the wire colors are as follows black with purple stripe,red w/pink,blue w/black,and solid black.)
I used butt connectors to re-wire and plugged the connector back in and SHAZZAM,horn and cruise control work once again.
For those that have similar problems and want to know the location of the horn relay.
There are three relays under the dash to the right side of the column,close to the center console(one is grey in color w/grey connector the other two are black one has a grey connector the other is black w/black connector(the horn relay is the one w/the black connector.)
I hope this helps any others out that are fighting the same problems.
Now I am looking forward to my vacation and the long drive( except for having the kids couped up in the car that long for those that know what I mean.) thumbs_u thumbs_u
