kvm101
Hey check out this pic. That might be a good idea ! They S&K keep sending the right tooth count 38 driven sprocket but apparently there 4 differant widths ! The two they sent wont wrap around the chain completely. My original in the very front has scores just below the splines. The bushing is fine that it rides on but I figured based on advice to change it. My trans guy was like the plastic washer it sits on probably has metal embedded in it. Not ! This was a remaned unit. So it could have been rough itnernally before the build.
I did read how guys with gen II were changing sprockets to get better off the line.
I bit the bullet, more like blew the budget. Had the trans back together but still on the stand. Figuered I'm never going to have this out again, (hopefully)it would be ashame to put it back in with the stock clutch set up! Called the machine shop up friday morning, ripped the case cvr off, fed the 3 yr old and got the call to come up with the parts. Machining .040 off the forward pressure plate .010 per clutch to get 4 modified frictions in, (meaning instead of 4 now 6) .020 on the 2 intermediate presure plates to add 2 modified frictions (meaning not 5 but 6 frictions). A parts guy were I get the oem stuff was like yeah you'll probably blow the diff. Hope not, dont plan to. Yah never know.
Waiting on the machine shop:tumbleweed: Guy's a retired engineer from Lucent, formerly Att. At the looks of his shop he's not hurting for money.http://images3a.snapfish.com/232323232fp733;5>nu=3;56>779>253>WSNRCG=337863;356344nu0mrj
