Fan Relay, where's it at?
Hambony
Houston, Tx
Replaced the radiator fan (it was bad), thermo, temp sensor, and the car still runs hot. Took it to the dealer and they looked at it (for free, not bad), and said it was probably the fan relay module. (the fan still kicks in once the temp goes past the N, but won't come on when a/c is on). Where could that fan relay be, and can it be visually inspected to find out if it is bad. Thanks in advance
:mad:
pjtoledo
'ol man in the SHO
toledo,ohio,usa
V 6 SHO right? The fan relay is inside the CCRM,, that's the black box above the radiator. It cannot be opened and inspected. The radiator fan should also turn on when the cabin fan is turned all the way to HI. The PCM senses the coolant temperature and tells the CCRM to engage the fan relay, so, if the fan works at any temperature, the relay is ok. There are actually 2 relays for the fan, Hi and lo speed, both are inside the CCRM.
Perry Toledo,Ohio
Satchmoz
