Fan on with heat
SHO93OFF
Queens,New York
I Know the cooling fan is supposed to come on with the A/c but everytime i turn on the heat or defrost my cooling fan comes on, i dont think this is normal, ideas? 93 mtx
Defrost it should come on as the AC compressor is on too. Heat (Floor or vent) it should not.
93rev2sev
Hockeytown
Its supposed to come on with the heat, As stated. It helps dry the air as it defrosts the windows.
Axianator
I am a banana!
Roanoke, TX
so the fan is supposed to come on with the a/c and heat and also defrost ?
Not quite. Read again what Paul said. ;)
The climate control system should only activate your cooling fans under a mode where the A/C system is being utilized. In the case of the '89-'95 SHO, the A/C system is only used when the MAX A/C, PNL+FLR, FLR+DEF, and DEFROST modes have been selected. Occasionally, the AUTO mode will also activate the A/C system.
Satchmoz
