Exhaust Manifold removal
Status
Not open for further replies.
Anonymous
Philadelphia,PA
I tried searching for an exhaust manifold removal but nothing primarily showed up so I'm looking to see how you remove them cause they see a lil tight to get to the bolts .
BaySHO Performance
SF South Bay
Manual (MTX) or Automatic (ATX) transmission? Front or rear manifold? The heat shield is held on with bolts, but the manifold is held on with nuts. If this is the rear MTX manifold, there's not enough room to get it off. The cylinder head has to be removed with the manifold still attached to it.
Anonymous
Philadelphia,PA
it's a 93 MTX and I don't think I'm a do all that I'm better off just cutting the studs and drilling out the rest and installing helicoils
BaySHO Performance
SF South Bay
I don't think that's possible. Not enough room to get a cutting wheel in between the manifold pipes. You could take the heat shield off the front manifold so that you can see what you are dealing with.
Status
