I said I would publish the details of the engine support that I used during my clutch and transaxle service and here it is. You can also see the image of the design sheet and the support at work in the photos in the Clutch & Transaxle album... MODERATOR NOTE: Due to PhotoIsland.com shutting down as of 11/22/2004, sdpatt's photo albums are not currently available. This may be a temporary matter if and until he elects to host his photos elsewhere, but in the meanwhile if you need a picture, please FIRST try to search the forum to see if the picture appears elsewhere, and if you can't find what you are looking for, you might try sending sdpatt a Private Message politely asking for the specific photo(s) you're interested in.
After looking at the design sheet and the photos, I realized that the lateral reinforcements under the cross beam are not readily apparent. At each joint between the cross beams and the support pylons, there are two, traingular 2x4 pieces attached to prevent side-to-side motion.
