engine making terrible noise
EBOLA6
San Ramon (east bay)
93 atx 124,000 miles
Engine oil light came on week ago, however, i stupidly chose to keep driving without adding oil. Well, added oil but it may have been too late.
Engine is now making tumbling/grinding noise coming from left side of engine near pulleys. I think its coming from that light gray cover above pulleys that mounts on side of engine. Isn't there a chain or berings in there? How do i find out what it is? Should i remove that cover? If you know what it might be...how do i fix it?
I did a vcg/intake manifold, wires, plugs replacement 6 months ago with excellent results. Thanks in advance!
Mr Anonymous
Tire Wall
Which oil light, red oil pressure or yellow oil level?
If it was the red oil pressure light, your engine is probably toast. Drain your oil and look for metal. It might be repairable with just new bearings, but more likely you'd be looking at at least one rod ruined, plus the crank.
If it was the yellow light, or you don't find any metal shavings in the oil, try to pinpoint the noise by using a mechanic's stethoscope (about $8 at most auto parts chains, or you can use a wooden broom handle, dowel or something similar). I'd start by climbing under the car with the engine running and put the 'scope right on the oil pan. If the noise is coming from there, you now have what we call a "parts car".
Let us know what you find.
EBOLA6
OK...I think the problem might be my water pump. There is steam/water coming from where the pulleys are and the pulley going to the pump is shaking violently. What do you think?
Heathcotejosh37
