sho' nuff sounds like either the fuel pump or the fuel filter. Safty first, use a mallot and bang on the drivers side of the trunk (inside), that will cause the emergency full stop button to activate (it pops out), Start the car and let it run till it dies. You are ready to replace the filter now. The filter is easy to replace jack the car up on the pasengers side, use a pair of pliers to remove the clips, pull the old one out (whatch out for the gas) put new one in, push the button back in, pump peddal a couple times, good to go.
shotime2669 definitely your EGR tube is cloged. Simple to check. Pull the air intake hose off the intake, push the butterfly open and peer with a flashlight inside. There are two holes on top, and two on the bottom. You will probably see a bunch of gunk in them. Solution: pull the intake off, take your time, buy a lot of B-12 chemtool and a few tooth brushes. I found a allen wrench is good if the gunk is really coked in the holes.
KYSHO When the a/c is on, you will loose some power because it is belt driven. I am betting that you are not use to the power draw sense it has not been on for a while and(Knock on wood)not the compressor
Hope this helps.
Eric
