Ebay Gen2 LED Tail Lights Installed!
SHO Continental
Moderator
Northridge, Cali
I believe I'm the first to get them on. :evilgrin: Any who... they will need the grote flasher to work correctly. It is only with the lights on and the brake applied that you get the fast signal flash. Lights on or off with no brake and the signal works fine. Lights off with brake and the signal also works fine. The wiring all plugs in perfectly, using the original plugs, they then go into the housings like normal. Perfect plug and play just needs the grote flasher. My only disappointment is with the design of the reflector. There's simply barely any reflector material on these lenses. I do like the clear lens though. Videos are on the bottom.
Dsc10095
reflector
Dsc10093
Very good fit
Dsc10098
Wiring, straight forward, make sure the connector is the correct direction, they only plug in one way.
Dsc10096
Dsc10113
Parking lights. Don't seem to be very wide angle LEDs, I'm sure it won't be a problem at all for anyone behind you. But it's the details.
Dsc10100
Dsc10099
Dsc10101
Brake comparison, lights are on. (Note my brakes were only lighting up the outer set on the stock lens.) My lights were tinted. The LEDs are MUCH brighter. Sorry I do not have a stock vs LED pic.
Dsc10112
Videos, the signal is on in all videos.
Lights on.
Lights off with brake applied
Lights on with brake applied.
I didn't get a video of just the signals by themselves without the brake or lights on, but I'm sure you can imagine what it'll look like.
droptSHO
Wheaton, IL
Those look great! Need to get me a set......with a light smoke of course. It uses the stock bulb for the reverse lights, right?
And I want your trunk.
stensg
fargo ND
Wow
if i didnt alredy have custom brake lights in the progress i would get them well i havent filled in my factory tail lights yet hmm... guess i got to finish my wing and brake ligh idea first
Calypso
**** Deer
Grand Rapids, MI
Those look nice. Let's hope they fab some up for the G1 sometime soon. Either that or I'm getting custom ones...
Phoenix
SHOHOLIC
QC , Canada
wow you got them fast. damn californians :evilgrin: Ill prolly get them in a week or so.
They look danm good. :thumb:
Kens1992mtxSHO
The Commonwealth
Saw this post and I knew I had to have a set. I bought the last set on ebay tonight
spazmoid
RI
am i correct in saying that the turn directionals blink really fast in the last video?
Shopower400
Atlas
Electric City, NY
How Much?
I have limited access with computers overseas as they block just about everything. Those taillights are SICK! I am curious on a price so i can budget myself accordingly. If i had to guess i'd say 250-300???
spazmoid
RI
yup i forgot to read, but you would figure aftermarket lights would include the correct resistors to make it a true plug and play install
Shopower400
Atlas
Electric City, NY
Scratch that. I found the price:thumb: My next question(s) is about the grote flasher. How much?, where can I find one?, and how do I install it? I really want these to "protect" my SHO as I was rear-ended 2X's in my old SHO and don't wan't a repeat!!! If you can't see those things you have no business being on the road:zoom:
Kens1992mtxSHO
The Commonwealth
Quick Question, how many flashers do you need? One per light or just one???
SHODOGG
Crowd Control
SHOCAGO
man I want those SOOOO bad...I just cant afford them right this second... :(
ManySHOs
South Jersey
Negative. The rate of flash is controlled by the flasher itself. Resistors are bad news. They get hot and melt things. The proper way to do it is to use an LED flasher.
Ian
Phoenix
SHOHOLIC
QC , Canada
Ok I got mine today , damn they look nice.
Fast shipping , 4 days from CA , I think its a record.
