quake
3.2 mtx,bbb,cams,48#injec,80maf,3.27 S/C pully,10psi of boost.Whats wrong with this picture.Afr is even across the board
nothing...you went supercharged...
We found belt slip at dyno. The afr is good cross the sheet.Got the belt slip take care of while i was there.6300 power fell off at that point.My setting rev 7800,bbb set at 3400,idle 1000,And far as boost 10 was what the donor car was pushing.It was dyno at at 312fwhp. Afr 11 to 13
I thought with FI you wanted to run a little richer than that....could be wrong though.
Yea, you're after stoich or slightly richer under full boost. His car is either pulling timing or he doesn't have enough fuel.
Edit: Michelle will run the ink pen out in here![]()
I know people used to buy those Reichard pulleys and modify the tensioner to combat that. Do you know any other tricks Sam?
Definitely not. Stoich is 14.7 and I would recommend between 11-12:1
Fuel=safety
Running no intercooler gets things real hot, even more so with 10psi or more. When you have stock pistons and charge air temps, you need more safety. The two things that keep your pistons from melting or cracking is cooler air temps or pulling timing. Since you didn't give it cooler air temps the computer took out timing. My car ran VERY well, and it did so on stock pistons over 13psi. It was intercooled with between 10.5-11.5:1 AFRs and lots of timing pulled.
