Drivers door actuator?
randy'sho
95 White MTX
High Point, NC
1990.....press the door locks and all doors lock accept for drivers door....makes no noise at all. Locks manually...but nothing electronically. I've been searching and it sounds like a possible actuator???
tommyturbo
California
just did mine. it's a pain. hard to get your hand into the door down there. check to see if the rivet popped first, as that will just allow the solenoid to move around in the door. That happened on my 90. On my 95 the solenoid just started buzzing but not locking or unlocking.
The part is a bit over $40 on rock auto.
definitely check the wiring stuff first, as the r/r of the actuator is a real pain.
sho'noff
shoverdrive
the land of the setting s
the passenger side window motor on the 95 sho here wasn't going back up for a year or 2 so I got another one at the wrecking yard and found out it was the switch so I messed with it and it is fixed aaah fresh air at last.
