Best Sho
This the 'Neutral Safety Switch' or the 'Starter / Clutch Interlok Switch'
I replace it with a new on and both are still doing the samething.
After hooking it up then pressing on the clutch pedal, the plastic piece (chrome arrow) slide to the end of the rod.
I want to drill a hole 1 inch from the end of the rod and put in a 'hitch pin clip'. To stop it from sliding.
The car won't start, battery good and starter not clicking.
It 94 Sho 74k miles 5 speed
Thanks
Thanks
by installing a toggle switch after bypassing the stock switch. the switch in mine still works but I cut one of the wires and put in a hidden toggle switch, when it's off the car wont start if the clutch is in or not.
