Door Side Light Thingys
Rob94
Northbridge MA
It's just a 194 bulb, right? If so, try pushing a piece of vacuum hose over it, then pull it out that way. Or, you may have to gently push in and rotate the bulb to remove it.
Camarok
Awesome SHO Member!!
Milwaukee, Wisconsin
take the door panel off and do it from the inside.... really not hard
There are 2 screws in the handle that you pull close... just pry off the 2 little covers, then the plastic piece by the power mirrors one screw that holds it on, then there is another right behind it... then!... by the littel storage thingy in the door there are 2 and you might have to take off the litte "brush" by the door opening handle on the inside.... ( I think that's it) and then just pull it off, it'll make poping sounds.
