Does 92 SHO have VAPS
Maybe.
You will have to look at it and see.
A VAPS rack has the additional mass of the VAPS Motor on the main body. It also has a total of four electical wires going to it. A non-VAPS rack has only a pair of wires in the connector.
Just keep in mind that if you use the SLO-standard rack, you might have problems with the tires rubbing in sharp turns, especially if you have wider than normal tires.. The SHO-specific racks were supposed to have travel limiters installed on the rack.
EZ4U2ENVY
schaumburg, IL
I was asking because im gonna be purchasing a 92 SHO so i thought someone here should know off hand if it did-
EZ4U2ENVY
schaumburg, IL
variable assist power steering- AKA VAPS.. it makes steering so much easier- but since ford sux at suspension the vaps can sometimes over compensate and make oversteer and understeer worse.
