Displaced Valve Guides
Shamwow
Michigan
Hello, Mike here from Charnal House Racing.
We run the MetSHO in 24hrs of lemons; a geo metro with a mid mounted SHO drivetrain.
0CF6B815 E7E7 43CE AD59 E976DF3EACD8 zps3hq2fhdg
I was prepping our original 3.0L engine to go back into the car this weekend. I used this engine for 4-5 races until it started burning oil excessively. Since compression was good and I noticed oil on one exhaust valve, I figured it was valve stem seals. I bought some new stem seals from felpro and set about installing them when i noticed something weird. The new intake valve stem seals were clicking into place just fine, but the new exhaust stem seals did not have any press fit onto the valve guide.
This is because the top of the valve guide has sunk down into the head! The lip that normally catches the seal is below the surface!
On cylinder 1 and 2, 3 out of 4 exhaust valve guides had moved. Here is a picture
"Good" valve guide. On this guide, the stem seal installed normally and clicked into place.
3B7C26D1 86EE 4632 BB16 2110FFACDCC3 zpsfsbnmvq0
"Displaced" valve guide:
5C2F641A 6218 448C A428 DB8237A0200D zpsicafqhsb
Displaced guide from the top. Notice how there is nothing for the stem seal to grab onto:
034C4F23 16BD 4B12 95C9 DE18E1884EDF zpso7ui1a6k
Anyone seen this before? This motor ran great when pulled except for burning a little oil as mentioned above. We did overheat it badly once (260f) and it spent most races running at 220F coolant temps.
I have seen this once on one SHO motor of the many I have been into. I think the overheating is the issue.
you can change the guides, or just put some "good" used heads on the motor.
zak
east of Hartford
Agreed on the overheating - aluminum expands more than the cast iron guide and the press fit is lost. If you are on a budget have the heads checked for flatness and then push the guides back in. Maybe run separate oil cooler to help shed heat?
