DIS Help A.S.A.P.
Kens1992mtxSHO
The Commonwealth
I have seen people use dielectric grease, but I wouldn't run it for too long. The heat sink compound is designed to spread the heat and cool the DIS.
hawkeye18
Sorta cares
Norfolk, VA
In a pinch, the DIS *should* be ok without anything for a day or two. At most. Keep mileage to an absolute minimum, and keep idling to a minimum as well, as idling generates more heat at the DIS than cruise does.
When Radio Shack opens up again, go get a tube of heat transfer compound or heat sink paste (it's all the same thing) and apply as such:
Untitled
Phoenix
SHOHOLIC
QC , Canada
Grab heat sink paste in a computer store , the heat sink used for processors. Works like a charm.
SHO_N_GO
95 MTX
Fort Rucker,Al
I found some looked on autozones web site found it went back to the store and told them to look it up and what do you know they had 3 of them so i grabbed 2
tompumped
VT
I don't think it matters too much if you apply it exactly like the diagram. I recently pulled mine off to put some fresh compound on it, and there was practically none on it. I'm surprised I didn't fry my module.
hawkeye18
Sorta cares
Norfolk, VA
Nah, it doesn't matter. As long as it all has coverage you're good. The chart is to disabuse people of the notion that one dab in the middle is enough. Which I have seen. It's not good.
