93rev2sev
I want to replace my factory amp/s.
My current setup is:
Cheap kenwood head unit running speaker wire from the H/U directly to the speakers and an RCA preout running to a decent kenwood amp and then to a JL 8" in the factory sub enclosure - the sub sounds great.
I have a perfectly good factory JBL premium sound receiver and CD player (separate) sitting in the parts car.
I want to install the factory receiver and CD player from the parts car and drive some new speakers with new amps.
I am having trouble finding a harness adapter that will connect to the gray data cable in the trunk and convert the signal and connectors to RCA connectors so that I can install decent amps to drive the speakers while retaining the factory look and data cable. Plug and play connector to the data cable is key.
Some of you might ask "why not replace the head unit and run RCAs from that to the trunk?" I have done this before and have not been happy with the level of RFI.
So in the end, I want to have a factory reciever, a factory CD player, factory data cable, aftermarket amps, aftermarket speaker wire and aftermarket speakers. Yes, a "sleeper" audio system is my goal.
Does anyone have a source for an adapter from the data cable to aftermarket amp - model number would be great? Crutchfield does not appear to have the adapter.
