cruise steering lights
RED95SHO
Windham NH
Tried several seaches with no luck. My steering wheel lights for the cruise are not working. No other lights are out. Are there lamps in the switches? How would I go about replacing or repairing?
SHO92
Upper Freehold, NJ
The switches from an Explorer do light up, along with others, but the Taurus switches don't light up. I remember many years ago a guy retro'd the switches from an Explorer, but he had to go through a lot of work to do it since there is no illumination wire in the column of the Taurus. You might be able to find a switched 12v and have the lights on whenever the car is on.
I think its more trouble then its worth.
jelloslug
Digital
Greenville, SC
If you want to add lighted buttons and you need the extra wire in the clockspring you will need to order a different clock spring. I ordered a clock spring for a Limited Explorer w/ wheel mounted radio & A/C controls PN: XL2Z-14A664-AA, it was like $25 or so. It bolted right up to the column and fit perfectly. You will have to modify the wiring some though as the airbag connectors are different.
1993MTXSHO
Its a Taurus...
Jersey
if you drive the way you're supposed to aka hands on 2 or 3 and 9 or 10 just feel for the big left hand bulging button, thats on, the the other right hand bulging button thats set cruse below that is the recessed coast button above that is resume? I dunno havent driven a sho in 2 years. Its definitely more trouble then its worth just memorize where the buttons are they arnt hard to find:thumb:
93nighthawk
Mitchell, SD
I must have driven Fords for way to long, I have the pattern memorized. Left thumb upper on, right thumb center to set, up to speed up, down to slow down.
Whenever I get into another make I am totally lost on setting the cruise. :oogle:
1993MTXSHO
Its a Taurus...
Jersey
yey i was right:woohoo:
jelloslug
Digital
Greenville, SC
What year Explorer had the lighted cruise buttons?
Mostly late model versions. Some of the high end models back to the mid '90s had them also. Be forewarned though: this is not a drop in swap, it takes a considerable amount of modding to get it to work including swapping airbags.
