Cruise Control Not Working
EO's SHO
Saint Louis, MO
My cruise control or speed control recently stopped working. I checked the fuse and its fine, my horn work fine. But, when I ran my codes I got a 452. Has anyone dealt with that before? I have a 93 ATX, 170K mi. Thanks.
DTC 452 is a VSS error code.
  • Continuous Memory DTC 29 or 452 indicates that sometime during the last 40 or 80 warm-up cycles, the Powertrain Control Module (PCM) detected an error in the vehicle speed sensor output signal.
    Possible causes:
    -- Damaged Vehicle Speed Sensor.
    -- Damaged harness circuits.
    -- Damaged Powertrain Control Module (PCM).
    l Perform VSS Drive Cycle at least three times as outlined below.
    VEHICLE SPEED SENSOR (VSS) DRIVE CYCLE:
    -- Record and clear Continuous Memory DTCs.
    -- Warm engine to operating temperature.
    AUTOMATIC TRANSMISSIONS:
    -- Place gear selector in DRIVE range.
    -- Obey all local traffic laws. Accelerate heavily to 35 mph.
    -- Coast down to an idle and stop the vehicle.
    -- Shut the engine off.
    -- After the drive cycle is completed, run Key On Engine Off Self-Test and record the Continuous Memory DTCs displayed.
    MANUAL TRANSMISSIONS:
    -- From first gear, shift to second.
    -- Obey all local traffic laws. Accelerate moderately to 40 mph.
EO's SHO
Saint Louis, MO
Thanks I'll give it a try. Will doing this make my cruise control come back? I'm planning a trip to Chicago in a month and it will be nice to not have mash my foot down for 4 hours.
Be sure to check the obvious and see if the linkage is still attached to the TB.
