Crankshatf pulley...
91 Plus
Well-Known Member
Monroe,Michigan
Ok here is the problem..Trying to change wp,timing betl,cps and all the goodies on a friends sho..I am down to the pulley I got the bolt off...The pulley puller I have you use the bolt still and you try and back the pulley off!The bolt broke off inside the pulley..Now how do I get this damn pulley off?Tia
Yamaha V6
SHO Enthusiast
Rhode Island
Use a larger "hook" type puller instead if possible, or drill out the bolt.
Bummer.
FYI, I have been able to use one bolt on one that busted off inside there, but I had already loosened the crank pulley on the crankshaft somewhat first.
Also, drill that bolt out anyway when you get it out, otherwise you may throw the balance off.
Gloffer
Glendale, AZ
I would probably help to spray the area where the pulley mounts to the crank with some PB Blaster. This will help break-up the corrosion that may be impeding pulley removal.
