Crank with No start ??? New Guy
Twisted99
South East
My 95 mtx will turn over but not try to start. The tach reads about 2-300rpm while cranking. I tried pulling the codes but had disconnected the battery prior to that. Also having trouble decyphering the code...I get a flash...pause then 2 flashes...pause two flashes...long pause flash....pause three flashes....
Will these cars run if the TPS sensor is below range? Will they start with a bad tps? It has 162000 on it. I have put new plugs and wires in once..run a K&N filter,use mobil 1...had a new clutch at 65000..new brakes and struts recently....Never changed the timing belt yet have one in the trunk. I did change the cam position sensor last summer. Yes there is some oil and coolant leaking around the crank pulley. Will the crank poistion sensor send 2-300 rpm if it is bad while cranking?
I bought this car new in 95.
Thanks ...
nothingtoseehere
When my CPS went bad, it hung at very low rpm while cranking.....if you have coolant leaking from the waterpump, chances are that the CPS you put in last year will need replacing again.
David Carpenter
