crank tap question ASAP
liquidmpls
Minneapolis MN
ok so i did the search and read the other posts about the snap-on tap or the mac tools set for when you strip the crank threads by misusing the puller.
i was going to order the set when i thought i would just call the local NAPA for jokes. The guy said that 14mm 1.5 is what spark plugs are so I could just use a sparkplug tap. and he said it was a very common tool and they had it in stock.
so here is my question...
can this be true, is it the same thing?
i am just leary becuase everyone else had so much trouble finding one and even from snap-on had to be ordered, and then this tiny NAPA just four blocks from my house says its a very common tool becuase its spark plug size.
any imput would be great, i just dont want to use the wrong thing or delay on ordering if i need to be ordering the correct one from the web.
Is this
Look very closely - that 14 mm tap is probably a different pitch - most likely a 1.25. Remeber, you need a 1.5 pitch.
I inspected a variety of spark plug thread chasers including at NAPA before giving up and ordering the Snap-On.
Hold the offered tap up to the threads of your crank bolt and see if the threads match up. If you get lucky, buy it!.
<small>[ January 20, 2004, 03:38 PM: Message edited by: projectSHO89 ]</small>
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Yes, righthand thread is normal.
Left hand thread is backwards (ie. righty loosey, lefty tighty).
liquidmpls
Minneapolis MN
great, ordering one from snap-on then.
any tips on using one? i have never done it and am nervous about wrecking my crank
91taurisho
my house, CO
liquidmpls:
Thread it in just like the bolt and turn it. after a full turn, back it out about a half turn. then start over. It is a vary long process but well worth it IMO.
Good luck thumb
Electricat
Decatur, IL
It is also a good idea to use a bit of oil on the tap, to help lubricate it and prevent any possibility of it seizing up. This isn't a necessity, but it is a good precaution. Since you just cleaning up existing threads, instead of cutting entirely new ones, this should really be quite an easy and quick job.
Dont' feel bad, I did the same thing to my crank last week! :eek: I don't seem to have hurt the threads tho, lucky I guess.
liquidmpls
Minneapolis MN
ok other than use oil and go slowly, can anyone give me any advice on how to make sure its lined up with the previous threads? i dont want to cut new ones that dont match the old ones.
Just square it up and turn it in. I just used a ratchet with a 12 pt socket that fit the end of the tap.
The tap is tapered so that you will have an excellent chance of it picking up the threads correctly.
When I did this, it literally took only 30 seconds of work after worrying and agonizing over doing it correctly.
Yamaha V6
SHO Enthusiast
Rhode Island
There is an excellent new tool for tapping pre-existing threads somewhere (like spark plug threads); it begins INSIDE the thread, with a "catch" to trap the particles so they don't fall into the combustion chamber. While that's not anything you have to worry about with the crankshaft, the 'starting inside' / lining up the threads & chasing from the inside-out sounds very appealing.
Saw it in one of the car mags recently - Hot Rod or Car Craft, can't remember which.
