Crank Repair Sleeve
Stoney
edmonton
Where can i get a repair sleeve for my crank seal i guess its called the front seal the one on the crank faceing the passenger side of the car.. the seal went and is leaking onto the exhaust and i replaced the seal hard job but the crank was grooved and it was all put together cause i was at a rental bay and was out of time now i want to go do it all again with a whole new kit with a sleeve and anyone know how they go in? or how hard it is? please tell me i dont need a new crank this engine runs solid and this is the only problem
LaTechSHO
Louisiana
to my knowledge, no one makes a repair sleeve for the front of our crankshafts..... there are sleeves made for the cam seals and the rear main seals....but nothing for the front crank seal....
good luck finding one
Louis
Ishodu
There are speedy sleevs for almost any sized shaft. They are around you just have to go to a industrial supply store. After you measure the shaft with a micrometer. Tell them the size of the shaft and they will get you a sleeve. Or if you get someone with a brain behind the counter just give them the seal # and they will get you the right sleeve.
Satchmoz
