Cornering bulbs on front bumper
SilverSHO
cartersville
Is there a trick to removing the bulbs from the curb lights on the sides of the front bumper? I tried earlier this evening to remove a burnt-out bulb from the left side lamp, and have a cut on my thumb for my effort.
Nick
Lt. Titanium 90 137k
Coneless, ACCEL 8.8 stainless steel wires,
SHO Shop solid roll dampers, Cherry Bomb Turbo II mufflers, snazzy blue valve stem caps
AIM: loudog6491
Bizzy
Take the screws out and it'll fall right out from the front. Much easier that way than to try and stick your hand inside to do it. Assuming it's the same on your car as my 91.
SHO's are like kids...they test your patience but you gotta love 'em!
Beth
'91 Plus MTX, Mostly stock
K&N Filter, Coneless
Colgan Custom Bra
Racing Series Driving Lights
Mods in the works
Many items on wish list!
SilverSHO
cartersville
I think I'll try that. At least I'll be able to see what I'm doing.
Actually, I meant getting the bulb itself out of the socket. I tugged on it pretty hard, and it didn't budge. Is the bulb clipped into the socket, or is it just hard to remove?
munkee
Too busy...
Missoula, MT
SilverSho I would suggest two pairs of pliers. Just be careful you don't crack the socket side.
Bizzy, I also have a 90, where are the screws you remove at?
"It's not just the speed, it's how well you handle it."
SilverSHO
cartersville
I figured it out. On the socket there is an O-ring around the end that goes into the lens. You have to take that off, then there is a clip around the base of the socket that holds the bulb in place. Take that off, then simply pull the bulb out. Once you have the new bulb in place, push the (square-shaped) clip back into place, replace the O-ring, and put it back in the lens.
