cooling fans continue to run while driving
mclark
mississippi
Took my 94 sho atx to mechanic for ac repair. Cooling fans was operating properly until the ac repair was attempted. Went to pick up the sho and noticed the fans run constantly. He stated that ccrm might be stuck, replaced ccrm fans still run.I noticed that the wires at the ccrm connector had been tested. Replaced the ac clutch, still no air. He stated that it is losing connection,at what point he dont know.My concern now is getting the fans to operate properly.Any help is good.
cooling fans running constantly is a symptom of a bad ground on the pcm.
does the car run? what are the codes?
btw, you need a new mechanic...
mclark
mississippi
Car does run, he stated that he cant pull the codes he dont have connector for that model.
well, you not only need the paperclip, you also need to be able to count to 9...
